Previous Topic: Create a Host Application Mapping Rule
Next Topic: Edit Application Mapping Rules
Create an All (ToS) Application Mapping Rule
Create an All application rule to combine traffic that has a common ToS value. The All application rule lets users easily report the total traffic for a particular service type.
  1. Open the Application Definitions page:
    1. Select Administration from the NFA console menu.
    2. Select Application Definitions in the Administration menu.
    The Application Definitions page opens.
  2. Verify that Application Mapping is the selected value for Rules.
  3. Click Add Rule.
    The Add Application Mapping dialog opens.
  4. Select All from the list of rule types at the top of the dialog.
    The Add Application Mapping dialog switches to All (ToS) rule mode.
  5. Specify values for the following settings:
  6. When the values are correct for all the required fields, click Save.
    The Add Application Mapping dialog closes. The new rule is included in the Application Mapping rule list.
  7. (Optional) Run reports to verify that all of the traffic on the designated target port fits the rule.
  8. (Optional) Once you notice the effects that new or changed application mapping rules have on reports, you may want to rename the protocol to identify it more clearly for other users.
