Previous Topic: Create and Manage ToS Groups
Next Topic: Change the Contents of ToS Groups
Create ToS Groups
You can create ToS groups to help users get optimal results from custom reports and analyses.
  1. Select Administration from the NFA console menu.
  2. Select Groups: ToS Groups from the Administration page menu.
    The ToS Group Configuration page opens and displays information specific to the selected ToS group and domain.
  3. Click Add.
    The ToS Group Configuration page displays options for identifying a new ToS group.
  4. Enter values in the Name and Description boxes, then click Add.
    A new shell group is created. You return to the ToS Group Configuration page. The new ToS group is added to the ToS Group Index dialog that appears in the Custom Report wizard.
  5. Add ToS values to the group:
    1. Select the new group from the ‘Select a ToS group’ list.
    2. (Optional) Select a domain from the Domain list, provided you have multiple domains available and you have created domain-specific ToS labels.
      Note: The Domain setting is displayed only when your environment has multiple domains configured. If only one domain exists, no Domain setting is displayed.
    3. Click Add/Remove.
      The ToS Index dialog opens. The ToS list displays the ToS labels that have been defined for the currently selected domain.
    4. Select the ToS values that you want to add by clicking their check boxes.
    5. Scroll to the bottom of the list and click Save.
    You return to the ToS Group Configuration page, which displays a list of the ToS values you added.
