Previous Topic: Verify That Data Is Received
Next Topic: Verify That the Interfaces Are Visible in the NFA Console
Verify That the Interfaces Are Enabled
Once you configure CA Network Flow Analysisto receive flow data, verify which interfaces are monitored.
  1. Open the NFA console, logged in with Administrator rights.
  2. Open the Available Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select System: Enable in the Administration menu.
      The Available Interfaces page opens.
  3. Expand the router details to display the interface list: Click the arrow to the left of the router name.
  4. Review the list to review whether the interfaces are enabled.
  5. Change the interface status: Select the check box next to one or more interfaces, then click Enable or Disable.
    The selected interfaces are immediately enabled or disabled.
  6. Repeat these steps for each router.
