Previous Topic: Expire Stale Addresses
Next Topic: Performing Advanced Administration
Service Management
You can start or stop CA Network Flow Analysis services or check the status of a service in the Windows Services window.
The CA Network Flow Analysis services are described briefly in the following list. If the CA Network Flow Analysis components are installed on more than one server, the services run on each server as shown in the following list. If all the components are installed on a standalone system, all the services run on the standalone server.
Service Log Files
The following lists identify the CA Network Flow Analysis service names as they appear in the Services window on Windows servers. The table also lists the services associated log file names and locations, along with the configuration file or Windows registry key that controls the log level setting.
NFA Console Server Services and Logs
Harvester Server Services and Logs
Services and Logs on All Servers
