Previous Topic: Add One or More Harvesters
Next Topic: Set Up the Routers
Verify the Harvester Domain
Verify that each Harvester is associated with the appropriate domain before you set up any router to export data to the Harvester.
Note: If you have not set up the domains you intend to use, set up the domains before you proceed. The routers that you configure to export to a Harvester are permanently associated with the domain of the parent Harvester. You will be able to change the domain of the interfaces that are associated with the router, however.
  1. Open the Harvester page:
    1. Select Administration from the NFA console menu.
    2. Select System: Harvester from the Administration page menu.
      The Harvester page opens and displays the current list of Harvesters.
  2. Click Edit on the row for the Harvester that you want to edit.
    The Edit Harvester dialog opens.
  3. (Optional) Change the Domain setting as needed.
    Default: Default Tenant\Default Domain.
    You can also change the IP Address and Description.
    Note: If no custom IP domains have been created, the Harvester table includes only the IP Address and Description columns.
  4. Click Save when you finish making changes.
    Your changes are saved immediately.
