CA Network Flow Analysis sends secure SNMP information to CA Performance Center at registration, then the information is transformed into SNMP profiles. SNMP profiles are definitions that contain the information necessary to enable secure queries of device MIBs using SNMP. Profile information is updated at each synchronization between CA Performance Center and CA Network Flow Analysis (every five minutes).
During initial product setup, you need to verify that the SNMP profiles you can see on the CA Performance Center Manage SNMP Profiles page are adequate to monitor your environment.
