Previous Topic: Processing IMS Transaction Information DataNext Topic: Job APCIJIFU—Importing the Data
Format Requirements for the IMS Transaction Information Interface
The input data for the IMS Transaction Information Interface must meet the following format requirements:
The execution information that you need to provide for each IMS transaction call is listedfollowing.
Required fields:
Field:
TRANSACTION
Description:
transaction name
Relative position in data line:
1
Format:
alphanumeric
Length:
1 - 8 characters
Range:
valid transaction name
Example:
DAT1, TRAN0001
Field:
IMS REGION
Description:
IMS region name where the transaction was executed
2
Format:
alphanumeric
Length:
1 - 8 characters
Range:
valid region name
Example:
IMS1, IR01
Field:
START DATE
Description:
date the transaction was started
3
Format:
numeric, date format YYYYMMDD
Length:
8 characters
Range:
valid date value
Example:
20081121
Field:
START TIME
Description:
time the transaction was started
4
Format:
numeric, time format HHMMSS.nn to HHMMSS.nnnn
Length:
6 to 11 characters, including the decimal point
Range:
valid clock time, with up to 4 decimal places for ten thousandth of a second
Example:
123118, 123118.12, 123118.1256
Field:
END DATE
Description:
date the transaction has ended
5
Format:
Length:
8 characters
Range:
valid date value
Example:
20081121
Field:
END TIME
Description:
time the transaction has ended
6
Format:
Length:
Range:
Example:
Field:
ELAPSED TIME
Description:
elapsed time of the transaction
7
Format:
decimal, from N to NNNNNNNNN.nnnnnn
Length:
1 to 16 characters, including the decimal point
Range:
0 - 999999999.999999
Example:
9, 15.2374, 145.873922
Field:
CPU TIME
Description:
CPU time consumed during the transaction execution
8
Format:
Length:
Range:
Example:
Field:
WAIT TIME
Description:
time the transaction was in a wait state
9
Format:
Length:
Range:
Example:
Optional fields:
Field:
DB2 REQUESTS
Description:
number of DB2 (EXEC SQL or IFI) requests issued by the transaction
10
Format:
numeric, from N to NNNNNNNNN
Length:
1 to 9 characters
Range:
0 - 999999999
Example:
0, 356823, 5923456
Field:
IMS REQUESTS
Description:
number of IMS (DBCTL) requests issued by the transaction
11
Format:
Length:
1 to 9 characters
Range:
0 - 999999999
Example:
0, 356823, 5923456
