When your application workload is distributed across multiple online regions, it is helpful to define region summary definitions.
All information about each of the single regions that are assigned to a summary region are put together and stored under the defined summary region name.
For example, if the INFO data contains information about transactions from regions IMSPRD1 and IMSPRD2 and you define a summary definition IMSPROD containing the 2 regions, then all information available for the 2 single regions will be aggregated under IMSPROD.
Select option I5 on the Parameters Menu to access the IMS INFO Aggregation Control panel shown following.
APCCPA00 --- PMA IMS Feature INFO Aggregation Control ------- Row 1 to 6 of 6 COMMAND ===> SCROLL ===> HALF Commands : INS - INSert Line Commands: I -Insert D -Delete C -Change LC PMA Region System Name Name ------------------------------------------------------------------------------- IMSSUM1 IMSSYS1 IMSSUM1 IMSSYS2 IMSSUM1 IMSSYS3 IMSSUM2 IMSSYS4 IMSSUM2 IMSSYS5 IMSSUM2 IMSSYS6 ******************************* Bottom of data ********************************
This panel displays the current defined aggregations.
You can insert (add) new definitions or delete or change existing definitions by using the following line commands:
Line command |
Function |
I |
Displays an input screen that is prefilled with the information from the line where the command was entered This data can be used as a model for building up a new aggregation definition by changing the System or Region name. |
C |
Displays an input screen that is prefilled with the information from the line where the command was entered |
D |
Deletes the selected definition A confirmation panel is displayed where you are asked to continue with the delete or to cancel the operation. |
You can also use primary command INS (Insert) to enter a new system aggregation definition. This command displays an empty version of the the System Aggregation Definition panel, as shown following.
APCCPA01 --------- System Aggregation Definition ---------- COMMAND ===> PMA System Name: Region Name : CANCEL: CAN OR PF3 SAVE : ENTER
