If you want to communicate with CA NSM Systems Performance Option Performance Trend using IPv6 addressing, you must configure the cube destination to use the IPv6 address of the CA NSM Manager node. You can do this at installation time, when you are prompted to "Enter the name of the CA NSM Management Station to receive the Performance Trend cube files". After installation, see the appendix "Using Performance Cubes" for configuration instructions.
