To start OpenVMS product daemons, add the following line to the OpenVMS system startup file SYSTARTUP_VMS.COM:
@SYS$STARTUP:CAPOLY$STARTUP
To shut down OpenVMS product daemons, add the following line to the OpenVMS system shutdown file SYS$MANAGER:SYSHUTDWN.COM:
@SYS$STARTUP:CAPOLY$SHUTDOWN
SYS$STARTUP:CAPOLY$STARTUP.COM starts the products selected for startup in the parameters file SYS$SPECIFIC:[UNIVMS.BIN]STARTUP_PARAMS.COM. During installation VMSINSTAL prompts you to choose the components that you want to start automatically and stores this information in the parameters file as shown in the following figure:
CA NSM for OpenVMS - product startup selection ------------------------------------------------------------- 1 CA Job Management ................................. YES 2 CA Job Management Agent ........................... YES 3 CA Universal Job Management Agent ................. YES 4 CA NSM Jobflow Support ............................ YES 5 CA Job Management NSM/CCS Integration ............. YES 6 CA Console Management ............................. YES 7 CA System Watchdog ................................ YES 8 CA System Watchdog NSM/CCS Integration ............ YES 9 CA Performance Management Agent ................... YES 10 CA NSM Performance Trend Cube ..................... YES 11 CA Common Services OpenVMS Gateway ................ YES
If you want to change the startup selection later, you can run the command file SYS$MANAGER:CAPOLY$SET_STARTUP_PARAMS.COM
