CCS for OpenVMS provides the application management environment and infrastructure to communicate with other CA solutions. CCS on OpenVMS consists of the following components:
The CCS startup command is the following:
@sys$startup:capoly$startup.com
The CCS shutdown command is the following:
@sys$startup:capoly$shutdown.com
For more information on starting and stopping CA Common Services, see the chapter “Starting and Stopping CCS.”
@sys$manager:capoly$set_startup_params
A menu displays the components you can configure.
