Previous Topic: Installing in a New Cluster
Next Topic: Choosing Installation Directories
Upgrading in a Cluster
Note: Upgrade from any release before 3.0 (sometimes named r3) to CA Job Management for OpenVMS Release 3.1 is not supported. If you want to install Release 3.1 on a system, which is running Unicenter TNG Workload Manager 2.4.2 or ScheduleIT 2.4, follow one of the options:
  1. Upgrade to 3.0 or 3.0 SP1, followed by upgrade to 3.1.
  2. Script all the jobs from your database. Uninstall the Job Manager/Scheduler from the system. Install CA Job Management for OpenVMS Release 3.1. Import the scripted jobs by running the script file to populate the job database. For more information about the SCRIPT JOB command, see the Command Reference Guide.
Release 3.1 of CA Job Management for OpenVMS includes database format changes. If you are upgrading Release 3.1 on a server in a cluster, do the following for the product to work correctly:
Note: Any jobs that are requested to run with override parameters using the command RUN /PARAMETERS=, but which have not run may need to be reset after the upgrade. The file TEMP_PARMS.DAT will be converted. Check the job before starting Job Management Manager after the upgrade.
