Previous Topic: Motif Interface Files
Next Topic: Uninstall Scripts
Uninstalling
Uninstall scripts enable you to easily remove CA Job Management for OpenVMS components. Two scripts are included for each component. One script removes both the base product and the CA Common Services Integration components associated with it. The other script removes only the CA Common Services Integration components. The command files to execute the scripts are located in the SYS$UPDATE directory.
This section contains the following topics:
Uninstall Scripts
