The following example shows the log file from a sample installation of the agent.
$ run $3$lda1:[000000]setup_alpha
UnZipSFX 5.20 of 30 April 1996, by Info-ZIP (Zip-Bugs@wkuvx1.wku.edu).
UnZipSFX is distributed by CA, Inc., and has been modified to spawn a subprocess
that installs either a product or a product patch kit. The original
distributors of UnZipSFX cannot and do not support CA's modified version.
Please see the Acknowledgements section of the CA OpenVMS product documentation
for more information.
inflating: ca$setup.com
inflating: installhelp.hlp
inflating: cajm_product.key
inflating: cajm$readme.txt
Setup location: $3$LDA1:[000000]
CA Job Management for OpenVMS
Copyright (c) 1990,2011 CA. All rights reserved.
PRODUCT
1 Job Management Manager Install
2 Job Management Agent Install
I CA NSM/CCS Integration Help
P Product Readme
H Install Help
E Exit
Please Enter the Number of the Product you wish to
install >>>> 2
%DCL-S-SPAWNED, process SYSTEM_39161 spawned
%DCL-S-ATTACHED, terminal now attached to process SYSTEM_39161
inflating: ca$setup.ini
inflating: unzip_alpha.exe
inflating: unzip_ia64.exe
Platform type : ALPHA
OS version : V7.3
Setup location: $3$LDA1:[000000.ENU.OPENVMS.JOBAGENT]
Product Kit : $3$LDA1:[000000.ENU.OPENVMS.JOBAGENT]UJMAGT_UNI_0000_yymmdd_V031.ZIP;1
* Enter the device and directory to unzip the save-sets, 110000 blocks of temp space needed [sys$common:[CA$SETUP]]:
UNZIP location: SYS$SYSROOT:[SYSMGR]UNZIP_ALPHA.EXE;2
Unzipping installation media ... Please be patient ...
OpenVMS AXP Software Product Installation Procedure V7.3-2
It is 23-NOV-2011 at 11:20.
Enter a question mark (?) at any time for help.
%VMSINSTAL-W-ACTIVE, The following processes are still active:
TCPIP$FTP_1
* Do you want to continue anyway [NO]? y
* Are you satisfied with the backup of your system disk [YES]?
The following products will be processed:
UJMAGT_UNI_0000_yymmdd_V V3.1
Beginning installation of UJMAGT_UNI_0000_yymmdd_V V3.1 at 11:20
%VMSINSTAL-I-RESTORE, Restoring product save set A ...
%VMSINSTAL-I-RESTORE, Restoring product save set Y ...
* DO YOU ACCEPT THE TERMS AND CONDITIONS OF THIS AGREEMENT AS SET FORTH IN THE LICENSE AGREEMENT (YES (Y) / NO (N) / VIEW (V)) [N]:
y
* Do you want to run the IVP after the installation (Product Startup Required) [YES]? y
The product will be started and the IVP will run automatically at the end of this install.
* Do you want to purge files replaced by this installation [YES]?
This product needs a TCP/IP network stack installed and
started on this node. You can use TCPWARE, MULTINET or
HP TCP/IP Services.
The TCP/IP stack TCP/IP Services is up and running...
%VMSINSTAL-I-RESTORE, Restoring product save set X ...
%VMSINSTAL-I-RESTORE, Restoring product save set R ...
The installation will now check the for the presence of an
OpenVMS account CAUNIVMS. This account is needed to support
the remote commands from the CA NSM management station.
%VMSINSTAL-I-ACCOUNT, This installation updates an ACCOUNT named CAUNIVMS.
The installation has detected the account CAUNIVMS. The installation will
skip the account creation. If this account is used by something other
than CA NSM, please modify the account name and re-install the product.
* Do you want to activate the CA Common Services Integration Components [YES]? y
The installation has found that CAM is currently running on the system.
In order to continue with the upgrade, CAM must be stopped. Other
CA software may be using CAM. If you are unable to stop CAM at this
time, the installation will exit.
* Do you want to stop CAM and continue Y/[N] [NO]? y
%UJMAGT_UNI_0000_yymmdd_V-I-EXISTS, Directory VMI$SPECIFIC:[UNIVMS.BIN] already exists.
CA NSM/CCS for OpenVMS - product startup selection
1 CA Job Management ................................. YES
2 CA Job Management Agent ........................... YES
3 CA Universal Job Management Agent ................. NO
4 CA NSM Jobflow Support ............................ YES
5 CA Job Management NSM/CCS Integration ............. YES
6 CA Console Management ............................. NO
7 CA System Watchdog ................................ NO
8 CA System Watchdog NSM/CCS Integration ............ NO
9 CA Performance Management Agent ................... NO
10 CA NSM Performance Trend Cube ..................... NO
11 CA Common Services OpenVMS Gateway ................ YES
* Are you satisfied with the product selection Y/[N] ? y
To complete integration with a CA NSM/CCS Management Station,
its IP address or node name is required.
The CA NSM/CCS Manager has been identified as:
"win2K3a"
* Node Name or IP Address [win2K3a] ?
%UJMAGT_UNI_0000_yymmdd_V-I-TRAPDST, The CA NSM/CCS Management station is set to "win2K3a"
%UJMAGT_UNI_0000_yymmdd_V-I-CREPRM, Created the file SYS$MANAGER:CAPOLY$SYSTARTUP.COM
%UJMAGT_UNI_0000_yymmdd_V-I-SETPRM, You can modify the selection later, using: SYS$MANAGER:CAPOLY$SET_STARTUP_PARAMS.COM
All questions regarding this installation have been asked.
The installation will run for approximately 2 to 5 minutes
%VMSINSTAL-I-RESTORE, Restoring product save set Z ...
Installing CA Message Service (CAM/CAFT)
Shutdown CAFT Daemon...
caftclose: server shutdown initiated.
Shutdown CAM Daemon...
camclose: server closed.
%VMSINSTAL-I-RESTORE, Restoring product save set B ...
Linking Agent...
Linking NSCHED$AGENT.EXE ...
Linking NSCHED$AGENT_IVP.EXE ...
Linking NSCHED$AGENT_SHUTDOWN.EXE ...
Providing files...
Providing NSCHED$AGENT.EXE ...
Providing NSCHED$AGENT_SHUTDOWN.EXE ...
Providing NSCHED$AGENT_IVP.EXE ...
Providing NSCHED$AGENT_DO_COMMAND.COM ...
Providing NSCHED$AGENT_RUN.COM ...
Providing Startup, Shutdown, Installation Verification
and Deinstallation procedures ...
Restoring the links saveset...
%VMSINSTAL-I-RESTORE, Restoring product save set T ...
Installing links...
To have CA Common Services started when rebooting, add
"@SYS$STARTUP:CAPOLY$STARTUP" to the system startup file,
either SYS$MANAGER:SYSTARTUP_V5.COM for VMS V5 or
SYSTARTUP_VMS.COM for OpenVMS V6 and OpenVMS V7, and add
"@SYS$STARTUP:CAPOLY$SHUTDOWN" to the system shutdown file,
SYS$MANAGER:SYSHUTDWN.COM.
%UJMAGT_UNI_0000_yymmdd_V-I-BUILDING, Linking CAPOLY$TNGD ...
%UJMAGT_UNI_0000_yymmdd_V-I-BUILDING, Linking CAPOLY$TRAP ...
%UJMAGT_UNI_0000_yymmdd_V-I-BUILDING, Linking CAPOLY$CASEND ...
%UJMAGT_UNI_0000_yymmdd_V-I-BUILDING, Linking CAPOLY$FORCEX ...
You may run the CA Common Services integration Installation
Verification Procedure at any time by typing the command:
$ @SYS$TEST:TNG$LINKS$IVP.COM
Product Management Command Files
Startup: $ @SYS$STARTUP:UNIJM$AGENT$STARTUP.COM
Shutdown: $ @SYS$STARTUP:UNIJM$AGENT$SHUTDOWN.COM
IVP: $ @SYS$TEST:UNIJM$AGENT$IVP.COM
Deinstall: $ @SYS$UPDATE:UNIJM$AGENT$DEINSTALL.COM
Common Component Command Files
Startup: $ @SYS$STARTUP:CAPOLY$STARTUP
Shutdown: $ @SYS$STARTUP:CAPOLY$SHUTDOWN
Reconfig Common Startup: $ @SYS$MANAGER:CAPOLY$SET_STARTUP_PARAMS
List Installed Products: $ @SYS$STARTUP:CAREGISTRY$LISTPRODUCTS [FULL]
Note: A call to the product startup procedure or common
startup procedure should be inserted manually in
SYS$STARTUP:SYSTARTUP_VMS.COM in order to start
the product automatically at system boot time.
Similarly, a call to the product or common
shutdown procedure should be inserted in the system
shutdown procedure, SYS$MANAGER:SYSHUTDWN.COM
%VMSINSTAL-I-MOVEFILES, Files will now be moved to their target directories...
%DCL-I-TABNOTFND, previous table LNM$SCHED_AGENT_TABLE was not found - new table created
%RUN-S-PROC_ID, identification of created process is 21A0043E
CCS OpenVMS Gateway Daemon Shutdown Complete
"win2K3a"
Note: You may change the list of products to be started on this node, using:
@SYS$MANAGER:CAPOLY$SET_STARTUP_PARAMS.COM
prior to launching this startup procedure...
"win2K3a"
Starting CAM Server...
%RUN-S-PROC_ID, identification of created process is 21A0043F
Starting CAFT Server...
%RUN-S-PROC_ID, identification of created process is 21A00440
Starting OpenVMS TNG Gateway Daemon...
%RUN-S-PROC_ID, identification of created process is 21A00441
Job Management Manager already running...
Job Management Agent already running...
Job Management Jobflow Daemon already running...
Job Management Event Message Daemon already running...
Beginning the Job Management Agent IVP
CA Job Management Agent, 0 jobs running, 64 jobs max
The Job Management Agent IVP procedure has completed successfully.
Starting TNG$LINKS$IVP
Sending IVP Request to node: win2K3a
wait 5 seconds
Checking node: win2K3a
................... Responded OK
All CA NSM/CCS Management stations responded!
CA NSM/CCS Integration IVP completed successfully!
Installation of UJMAGT_UNI_0000_yymmdd_V V3.1 completed at 11:27
Adding history entry in VMI$ROOT:[SYSUPD]VMSINSTAL.HISTORY
Creating installation data file: VMI$ROOT:[SYSUPD]UJMAGT_UNI_0000_yymmdd_V031.VMI_DATA
VMSINSTAL procedure done at 11:27
%DELETE-I-FILDEL, SYS$COMMON:[000000]CA$SETUP.DIR;1 deleted (16 blocks)
%DELETE-I-FILDEL, SYS$SYSROOT:[SYSMGR]CA$SETUP.INI;1 deleted (160 blocks)
%DELETE-I-FILDEL, SYS$SYSROOT:[SYSMGR]CA$SETUP.COM;1 deleted (160 blocks)
%DCL-S-RETURNED, control returned to process SYSTEM_5404
PRODUCT
P Product Readme
H Install Help
E Exit
install >>>>
