After Installing the CA Job Management Agent › Starting CA Job Management Agent
To start the agent, use one of these two methods:
- If you are logged into the SYSTEM account, enter the following to run the command procedure SYS$STARTUP:UNIJM$AGENT$STARTUP.COM:
$ @SYS$STARTUP:UNIJM$AGENT$STARTUP.COM
- If you are not currently logged into the SYSTEM account, you can start the agent by entering:
$ SUBMIT/USER=SYSTEM SYS$STARTUP:UNIJM$AGENT$STARTUP.COM
- If you are activating the Integration software, enter the following command to start up from the SYSTEM account:
$ @SYS$STARTUP:CAPOLY$STARTUP.COM
