Before installing the agent, perform the following procedures:
We recommend that you back up your system disk before installing any software. For information about backing up your system disk, see the documentation for the operating system involved.
Your OpenVMS HP Integrity Server should satisfy the general requirements outlined in the "Hardware and Software Requirements" section in Chapter 1 of this guide.
The system you install the manager on must have sufficient quotas to enable you to perform the installation and start the software.
The following minimum values are recommended for system parameters listed below:
SYSGEN parameter |
Minimum Value |
FREE_GBLSECTS |
20 |
GBLPAGES |
900 |
CHANNELCNT |
256 |
RESHASHTBL |
4096 |
LOCKIDTBL |
3840 |
Note: These are minimum quotas only and intended for systems with CA Job Management Agent-only installations. Higher values may be needed for other applications.
