Previous Topic: Step 18. Specify the UIC of the CAUNIVMS account
Next Topic: Backup of Job Management database and executable files
Backup of Files from a Previous Installation
If the installation is not a first time install on the node, the installation determines whether or not it should backup the existing files. There are two types of files that are backed up:
  1. Job Management database and executable files
  2. Startup files which define customized configuration
