You can install the manager on a standalone node. The installation procedure prompts you for two separate directories. This prompt is intended for OpenVMS cluster installations; however, for a standalone node, you also select the default answer to both prompts. We recommend that you use the default answers to place the files on device SYS$COMMON. This location lets you easily transition this node into a cluster in the future. You can accomplish this setup as follows:
The default answer to the prompt for the common disk, SYS$COMMON:[NSCHED], is valid on standalone nodes.
If the directory does not exist, the installation procedure creates it. You do not need to create it prior to installation.
When the installation procedure prompts you for a pathname to the node-specific files area, specify the selected directory. If there is sufficient space available on the device SYS$COMMON, selecting the default answer to the prompt, SYS$COMMON:[NSCHED] is a safe choice.
