Specifies the user string restart value, for the specified job from outside the job when the job is not running. SET JOB /RESTART_VALUE fails if the specified job is running.
See the command SET RESTART_VALUE for details about restart values usage, and examples.
To modify the restart value from a running job process, use the SET RESTART_VALUE command.
To clear the restart value previously set for the specified job, use SET JOB /NORESTART_VALUE. Alternately, you can use SET JOB /RESTART_VALUE="" (null string). Both clear the restart value.
