Specifies the end time of the interval for which you want to display the history information. The end time is an absolute value. Use the following format:
dd-mmm-yyyy hh:mm:ss.cc
The time must be enclosed in quotation marks (""). The default time for hours and minutes (hh:mm) is 00:00.
To use this qualifier, you must also use the /RECORDED_RUNS qualifier. The default value is the current time, which will display the latest records. Do not specify a time later than the current time.
