Date_spec is any valid OpenVMS date-time expression. Only the date portion of the specifications will be used.
This qualifier is used in conjunction with the /SD_CLASS qualifier to modify the dates contained in a Special Day Class. Dates can be added by using the /DATES qualifier, and specified dates can be removed by using the /NODATES qualifier. This qualifier requires the /SD_CLASS qualifier.
This qualifier is not supported with this command when a server is specified.
