Date_spec is any valid OpenVMS date-time expression. Only the date portion of the specifications will be used.
This qualifier is used in conjunction with the /SD_CLASS qualifier to create a Special Day Class containing the specified dates. Dates can be added or removed from the class by using the MODIFY/SD_CLASS command. This qualifier requires the /SD_CLASS qualifier. This qualifier is not supported with this command when a server is specified.
