The name or number of the job that you want to copy. For example:
SCHEDULE> COPY MYJOB SCHEDULE> COPY 123
For more information on description of job specifiers and how to use them, see the CA Job Management for OpenVMS Administration Guide.
SCHEDULE> COPY THISJOB=DOE
SCHEDULE> COPY NODE1::THISJOB SCHEDULE> COPY NODE1::456 SCHEDULE> COPY THIS JOB/SERVER=NODE1
The following example copies a job named THISJOB owned by user DOE on remote node NODE1.
SCHEDULE> COPY NODE1::THISJOB=DOE
Note: You cannot use wildcard characters in the job specifier. If you are copying a job belonging to another user, you must specify your own username unless you have the CMKRNL privilege.
