The name or number of the jobs you want to abort. For example:
SCHEDULE> ABORT MYJOB SCHEDULE> ABORT 123
The job specifier is required, unless you use the /GROUP or /TYPE qualifier. If you omit the job specifier, the manager prompts you for it. However, if you specify /GROUP or /TYPE, the manager does not prompt for the job specifier. The following example aborts all of your jobs that belong to group WEEKLY and type FISCAL:
SCHEDULE> ABORT /GROUP=WEEKLY/TYPE=FISCAL
For more information on description of job specifiers and how to use them, see the CA Job Management for OpenVMS Administration Guide.
SCHEDULE> ABORT THISJOB=DOE
You must have EXECUTE access to a job to abort it.
SCHEDULE> ABORT NODE1::MYJOB SCHEDULE> ABORT NODE1::321 SCHEDULE> ABORT MYJOB/SERVER=NODE1
You can use wildcard characters to refer to a job name, username, group name, and type name. For example, the following command aborts all jobs starting with the letter B that are in any GROUP starting with W and owned by any user whose name begins with D:
SCHEDULE> ABORT B*=D*/GROUP=W*
