The name or number of the job that you want to run.
For example
SCHEDULE> RUN MYJOB SCHEDULE> RUN 123
The job specifier is required. If you omit the job specifier, the manager prompts you for it.
To refer to a job belonging to another user, you must add the =username specifier to the job name. For example:
SCHEDULE> RUN THISJOB=DOE
To refer to a job on a remote node, add the node name to the job specifier. For example:
SCHEDULE> RUN NODE1::THISJOB
You can use wildcard characters to specify job name and username. For example:
SCHEDULE> RUN M*=D*
Note: When you use the RUN command with temporary overrides for any of the following values, the job will not be retried if the job fails:
Note: You cannot use override qualifiers such as /CLUSTER_NODE or /COMMENT if you are running more than one job at a time with a single SCHEDULE RUN command. For example, the following command is invalid:
SCHEDULE> RUN M*/NODE=NODE1
