Previous Topic: Format
Next Topic: Qualifiers
Parameter
value
Specifies a job priority value from 1 to 15 for the manager. If you try to set a value greater than 15, the manager automatically sets it to 15. If you try to set a value less than 1, the manager automatically sets it to 1.
Note: This run time priority should not be set higher than the normal priority for interactive jobs.
