Previous Topic: /RETRY /NORETRY (D)
Next Topic: /SD_ACTION=keyword
/RUN_PRIORITY=process_priority_value
Specifies the default process priority that the manager uses to run the job. The process priority is a number between 1 and 16. This qualifier is supported with this command only for /MODE=DETACHED jobs.
If you omit the value or use a less than or equal to 0, the manager runs the job at its default priority of 4.
If you specify a value greater than 16, the manager uses a value of 16.
The run priority should be set no higher than your system’s normal interactive job priority.
To choose a priority value for a Job Management Manager job, follow these rules:
Note: You need SETPRV or ALTPRI privileges to run a job at a priority value greater than the default priority for the manager or the job owner (UAF file). See your system manager.
