Specifies a file name to contain the job’s output, such as:
The file name can have up to 255 characters. The following is an example of a full file name:
/OUTPUT=MYDISK:[MYDIRECTORY]TEST.LOG
If you omit the device or directory, the manager puts the output in your default device and directory as specified in the authorization file for the account. If a logical is used to define the location of the file it must be a system logical; it cannot be a process logical.
If you specify /NOOUTPUT, the manager does not save the output.
