Directs the output from the command to a specified file.
For example:
/OUTPUT=CURRENT.DEFAULT /OUTPUT=[DOE.LOAD]CURRENT.DEFAULT
If you do omit this qualifier, the default file name is SYS$OUTPUT.
If you omit the file name extension, the default extension is .LIS.
