Previous Topic: /OUTPUT=file_name
Next Topic: /SERVER=remote_node
/PROCESS [job_id]
Mimics the SHOW PROCESS command from DCL. Operates on currently running jobs only. It may be possible to have this command return NO JOB FOUND for a job that exists in the database but is not running. This command does not show process dynamic memory and subprocesses but has all other support of the DCL SHOW PROCESS command.
When showing jobs currently executing under a different user name, the normal OpenVMS privilege rules are required and the identifiers are not used. So, in order to show another user’s process, GROUP or WORLD privileges are required.
