Specifies that the manager should prompt you with the complete set of qualifiers for this command. See the second example for the complete list of qualifiers.
If you do not specify either /PROMPT or /NOPROMPT, the manager prompts you for a subset of qualifiers: OpenVMS command, job name, interval, days, start time, output, and comments.
If you specify /NOPROMPT, the manager does not provide any prompts for qualifiers.
Note: You cannot use /PROMPT to modify several jobs with a single command. You must specify all qualifiers on the command line when modifying more than one job.
