Previous Topic: /PRE_FUNCTION=prefunction_command /NOPRE_FUNCTION (D)
Next Topic: /QPRIORITY=qpriority_value
/PROMPT /NOPROMPT (D)
Specifies that the manager should prompt you with the complete set of qualifiers for this command. See the second example for this command.
If you do not specify either /PROMPT or /NOPROMPT, The manager issues a standard subset of qualifiers. See the first example.
If you specify /NOPROMPT, the manager does not provide any prompts for qualifiers.
