Previous Topic: /PRE_FUNCTION=prefunction_command /NOPRE_FUNCTION (D)
Next Topic: /QPRIORITY=qpriority_value
/PROMPT /NOPROMPT
Specifies that the manager should prompt you with the complete set of qualifiers for this command. See the first example for this command.
If you do not specify either /PROMPT or /NOPROMPT, the manager prompts you for a subset of qualifiers: OpenVMS command, job name, interval, days, start time, output, and comments.
If you specify /NOPROMPT, the manager does not provide any prompts for qualifiers.
