Previous Topic: /START_TIME=starting_time
Next Topic: /SYNCHRONIZATION=(job_specifier, ...) /NOSYNCHRONIZATION=(job_specifier, ...) /NOSYNCHRONIZATION (D)
/SYMBOL=dcl_symbol
Assigns a DCL local symbol to the job number that the manager creates. Users can then reference the DCL symbols instead of the job number. For example: /SYMBOL=WRN or /SYMBOL=WEEKLY.
You can specify this qualifier only on the command line. The manager does not prompt you for a /SYMBOL value, even when you use the /PROMPT qualifier.
