Previous Topic: /FIVE_WEEK_MONTH=month
Next Topic: Example
/START_DATE=date
Base date for your fiscal calendar; all fiscal calendars are calculated relevant to this base date. This date defines the first day of a 53-week fiscal year. This fiscal year must not be a leap year (must not contain February 29th). The date has the following format: dd-mmm-yyyy (for example, 28-Jun-1981).
Fiscal years always end on the same day of the week. The manager supports both of the methods for determining the end of a fiscal year described in IRS Publication 538. These two methods are:
  1. The fiscal year ends on the last day of the week in the month.
  2. The fiscal year ends on the day of the week closest to the end of the month.
    The manager uses the base date given to determine which method to use.
    The following information discusses tips on how to choose an appropriate start date.
If you have access to your company’s fiscal calendar:
If you do not have access to your company’s fiscal calendar:
Make sure that the Fiscal Year starting with your base date is not a leap year (does not contain February 29th). Keep in mind that the fiscal year starting with your base date will be a 53-week fiscal year.
Note: As with the functionality of the Special Days support feature, if the Fiscal Calendar is modified in any way, the next run time of jobs will not be automatically recalculated until the jobs run again and recalculation occurs as a normal process. For those jobs that may be affected, users must manually modify the next run time of the jobs to reflect any modifications to the Fiscal Calendar.
