This example specifies /PROMPT, so the manager issues the complete list of qualifiers. The user makes the same modifications as in the first example.
SCHEDULE> MODIFY/PROMPT
_Job name or number : WEEKLY-RENAME
_VMS Command [@SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY_COPY.COM] :
_Job Name [WEEKLY-RENAME] :
_New_Group [WEEKLY]: DAILY
_New_Type [PROJECT-COSTS] : FISCAL
_Schedule Interval [F W6 18:00:00] :
_Days [(FRI]:)
_Special Day Restrictions [None]:
_Next Run Time [ 7-AUG-1996 18:00] :
_Stall Notify [None] :
_Stall Time Job [None] :
_Output file [SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY-RENAME.REP] :
_Mode (Detached, Batch, Remote [DETACHED]:)
_Cluster Node [Default] :
_Retain (Success, Error, None or All [ALL]:)
_Restart (Yes, No [Yes]:)
_Retry (Yes, No [Yes]:)
_Notify (Yes, No [No]:)
_Send_Mail (All, Error, Success or None [ALL]:)
_Send MAIL on Special Day Action (Yes, No [No]:)
_Use_next_time (Yes, No [Yes]:)
_OPCOM (Yes, No [No]:)
_Mail_Address [EXAMPLE] :
_Username [EXAMPLE] :
_Run Priority [Default] :
_Pre Function [DIR/PRINT [EXAMPLE.PROJECT-C]*.REP]] :
_Post Function [DIR/PRINT [EXAMPLE.PROJECT-C]*.REP]/SIN] :
_Maximum Time Warning [None] :
_Maximum Time Job [None] :
_Synchronization [None] :
_Comment [Check for weekly rep's/copy to subdirectory and
rename/check new rep files] :
%NSCHED-I-RQSTSUCCSS, Job WEEKLY-RENAME - Modified
