Sets the name or job number of the job to run when the present job has exceeded its maximum run time. If this job’s run time exceeds its MAX_TIME qualifier, then the specified job will be run.
This qualifier is not supported with this command when a server is specified.
Note: The max_time job (TJOB) must exist in the same database as the job that calls it.
