Previous Topic: Related Documents
Next Topic: Job Management Manager DCL Commands
Conventions
The following table describes some of the conventions used in this guide.
Convention
Meaning
UPPERCASE
Uppercase letters indicate the name of a command, a file, a parameter, a procedure, or utility.
In command examples, uppercase characters represent elements of a command that you should enter exactly as shown.
user input
system prompts
system displays
In interactive examples, this typeface indicates input entered by the user, a system prompt, or displayed system text. For example:
SCHED MODIFY job-specifier
The dollar sign is used to indicate the DCL prompt. This prompt may be different on your system.
Ctrl+X
In procedures, a sequence such as Ctrl+X indicates that you must press the key labeled Ctrl while you press the key or a pointing device button.
OpenVMS, VMS
The terms OpenVMS and VMS refer to the OpenVMS operating system.
