The system manager can turn load balancing on or off for an entire OpenVMS Cluster. Load balancing spreads the load of processing Job Management Manager jobs across all nodes of a OpenVMS Cluster, in order to achieve better performance.
If enabled, load balancing is performed by the default manager instance. Load balancing is applied to all jobs that do not have a /NODE restriction and are MODE=DETACHED jobs.
