Instructs the manager to prompt before deleting a Load Balance Group that is referenced by one or more jobs in the jobs database. The prompt is displayed once for each Load Balance Group listed in the delete command
Note: We recommend that you use the /CONFIRM qualifier if you are deleting more than one Load Balance group.
When you specify /CONFIRM, the manager uses the following prompt:
$SCHEDULE CONFIG DELETE LOAD_BALANCE_GROUP GROUP1 /CONFIRM The Load Balance Group GROUP1 will also be removed from the nn jobs that are still referencing it. Do you want to proceed [YES]/NO ?
Where nn identifies the number of jobs that are assigned to run under this Load Balance Group.
You can enter one of the following answers:
To... |
Answer... |
Delete the Load Balance Group and remove it from all jobs that reference it |
YES |
Retain the Load Balance Group and all references |
NO |
