Previous Topic: HOLD
Next Topic: Format
Description
To put a job on hold, you must own it or have EXECUTE access to it. For information on privileges, see the CA Job Management for OpenVMS Administration Guide.
The manager will not run a job that is on hold. You can run the job by using the SCHEDULE RUN command. You can take a job off hold by using the SCHEDULE RELEASE command.
