The default agent node runs all Job Management Manager jobs that do not have a node restriction, unless load balancing is turned on. For more information on OpenVMS Cluster support and load balancing, see the CA Job Management for OpenVMS Administration Guide.
The first node started on the OpenVMS Cluster becomes the default node. However, system managers can change the default node by using a SCHEDULE SET DEFAULT command.
Use SCHEDULE SHOW DEFAULT to see the current Job Management Manager default node.
