To copy a job, you must own it or have READ access to it. For more information on privileges, see the CA Job Management for OpenVMS Administration Guide.
You must have CMKRNL privileges to create a job with a username other than your own.
The manager prompts you for the values of a standard subset of qualifiers, unless you specify those qualifiers on the command line.
If you include the /PROMPT qualifier on the command line, the manager prompts you for all qualifiers. For example:
SCHEDULE> COPY JOBNAME/PROMPT
