When used with the /SD_CLASS qualifier, a Special Day Class is created. For more information on creating Special Day Classes, see the CA Job Management for OpenVMS Administration Guide.
When the /SD_CLASS qualifier is not used a job is created.
The created job consists of a system-level command to process, plus information describing when and how the job should run.
The manager assigns a unique number to each created job. You can assign the following job specifiers to refer to the job:
For more information about job specifiers, see the CA Job Management for OpenVMS Administration Guide.
By default, the SCHEDULE CREATE command prompts you to enter settings for a standard subset of its command qualifiers. If you use the /PROMPT qualifier with SCHEDULE CREATE, the command prompts you to enter settings for all qualifiers. The first example shows the default qualifiers, and the second example shows the additional qualifiers associated with the /PROMPT qualifier.
You must have CMKRNL privilege to create a job in another user’s account.
