To modify a job, you must own it or have WRITE access to it. For more information on privileges, see the CA Job Management for OpenVMS Administration Guide.
To modify one job, you can do one of the following:
To modify more than one job, you must specify any qualifiers that you are modifying on the command line. You cannot use the /PROMPT qualifier.
