Previous Topic: /VMS_COMMAND=vms_command
Next Topic: RUN NSCHED$:DB_UTILITY.EXE
Examples
  1. In this example, the hyphen at the end of the DCL command line extends the command to a second command line. The manager runs your job WKLY-RNM immediately. For this run only, the manager puts the job’s output in the file MYDISK:[MYDIR]TEST.LOG.
    SCHEDULE>  RUN WKLY-RNM/OUTPUT=MYDISK:[MYDIR]TEST.LOG-  _
    SCHEDULE> /CLUSTER_NODE=NODE1
    %NSCHED-I-FLAGSET, Job  WKLY-RNM - Run Requested
    Workload Scheduler Job 56  (Name: WKLY-RNM Started on node 	NODE1)
     Workload Scheduler Job 56  (Name: WKLY-RNM Completed on node 	NODE1)
    The job is run on node NODE1.
    When the job completes, the manager replaces the values for /OUTPUT and /CLUSTER_NODE with the original values for these qualifiers.
  2. This example is the same as the first example, but specifies /CONFIRM on the command line. As a result, the manager requests confirmation before running the job.
    SCHEDULE>  RUN WKLY-RNM/CONFIRM/OUTPUT=MYDISK:[MYDIR]TEST.LOG-
    _SCHEDULE>/CLUSTER_NODE=NODE1
    Job WKLY-RNM (56, RUN? [No]) YES
  3. This command specifies that the manager run the job on node NODE1. However, the manager is not running on that node, so the software issues a warning message. If the manager was running on NODE1, it would have run the job immediately.
    SCHEDULE>  RUN WKLY-RNM/CLUSTER_NODE=NODE1
    %NSCHED-W-NOSCHED, No scheduler available to service request
