Previous Topic: SET MAX_JOBS
Next Topic: Format
Description
If you do not specify a node, the manager places the job limit on the node you are logged in to.
The default value for the job limit is equal to the value of the logical NSCHED$DEFAULT_JOB_MAX. If you do not define NSCHED$DEFAULT_JOB_MAX, the manager uses a default of six jobs; this default value is in the system specific startup file NSCHED$COM:UJM$MANAGER$STARTUP_nodename.COM.
To see the current job limit for the manager, use the SCHEDULE SHOW MAX_JOBS command.
