Previous Topic: /WRID=identifier /NOWRID (D)
Next Topic: CREATE
Examples
  1. In this example, the user specifies the /PROMPT qualifier on the command line, so the manager prompts for all the qualifiers.
    SCHEDULE>  COPY/PROMPT
    _Job name or number: WEEKLY-RENAME
    _VMS Command [@SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY_COPY.COM] :
    _Job Name [WEEKLY-RENAME] :  weekly-rename1
    _Group [WEEKLY] :
    _Type  [PROJECT-COSTS] :
    _Schedule Interval [F W6 18:00:00] : d 4:15
    _Days [(FRI]:) ALL
    _Special Day Restrictions [None]:
    _Next Run Time [15-APR-1997 04:15:00.00] :
    _Stall Notify [None] :
    _Stall Time Job [None] :
    _Output file [SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY-RENAME.REP] :
    SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY-RENAME1.REP
    _Mode (Detached, Batch, Remote [DETACHED]:)
     _Cluster Node [Default] :
    _Retain (Success, Error, None or All [ALL]:)
     _Restart (Yes, No [Yes]:)
     _Retry (Yes, No [Yes]:)
     _Notify (Yes, No [No]:)
     _Send_Mail (All, Error, Success or None [ALL]:) none
    _Send MAIL on Special Day Action (Yes, No [No]:)
     _Use_next_time (Yes, No [Yes]:)
     _OPCOM (Yes, No [No]:)
     _Mail_Address [EXAMPLE] :
    _Username [EXAMPLE] :
    _Run Priority [Default] :
    _Pre Function [DIR/PRINT [EXAMPLE.PROJECT-C]*.REP] :
    _Post Function [DIR/PRINT [EXAMPLE.PROJECT-C]*.REP] :
    _Maximum Time Warning [None] :
    _Maximum Time Job [None] :
    _Synchronization [None] :
    _Comment [Check for weekly rep's/copy to subdirectory and
    		rename/check new rep files] :
    %NSCHED-I-RQSTSUCCSS, Job      10522 - Created
    The user copies an existing job called WEEKLY-RENAME to create a new job called WEEKLY-RENAME1. The following qualifier values of WEEKLY-RENAME are modified:
  2. This command specifies /NOPROMPT, so the manager does not display prompts. WKLY-RNM1 will run on a cluster node called NDNM.
    SCHEDULE> COPY WKLY-RNM/NOPROMPT/JOB=WKLY-RNM1 /CLUSTER_NODE=NDNM
    %NSCHED-I-RQSTSUCCSS, Job        296 - Created
