Previous Topic: Format
Next Topic: Qualifiers
Parameter
job_specifier
Specifies the name or number of the job.
For example:
SCHEDULE> SET MYJOB
SCHEDULE> SET 123
To refer to a job belonging to another user, add the =username specifier to the job name. For example:
SCHEDULE> SET JOB THISJOB=YOURNAME
To refer to a job on a remote node, add the node name to the job name or number. For example:
SCHEDULE> SET JOB NODE1::MYJOB
SCHEDULE> SET JOB NODE1::123
You cannot use wildcard characters for the job specifier.
