Specifies the OpenVMS username under which to run the new job. This value overrides the username of the person creating the job. For example, if the default username is MYJOB and you want the job to run under username YOURJOB, specify /USER_NAME=YOURJOB.
Note: You need CMKRNL privilege to use a username other than your own. You cannot use the /GROUP or /TYPE qualifiers at the same time as the /USER_NAME qualifier. This is designed to avoid the potential for error.
